HELP!! First time post.... Serious Power Loss!!!
Old Apr 13, 2008 | 09:54 PM
a41.8Tblk's Avatar
Default RE: HELP!! First time post.... Serious Power Loss!!!
i dont think so man, it was def a lot faster and i could def tell the difference in second. it just feels liek clogged or something. i have checked everting and replaced the ECT n75 and some hoses. now i think it might be the in line check valve or the EVAP or could it be the wastegate purge valve? im goign nutts over this!!!
Old Apr 13, 2008 | 10:01 PM
turbo kraut's Avatar
Tech Guru
i doubt anything is clogged........ do you have access to a compressor? do the diy vac test and check if you do, if not you could spend a few bucks and chase every hose and replace them all........ that will probably bring your power back..... that or you might have a cracked check valve that is leaking
Old Apr 13, 2008 | 10:15 PM
a41.8Tblk's Avatar
there is 2 or 3 check valves right? well i checked 2 and they seem fine, main thing is i just dont feel the kick from the turbo any more, i noticed that when i changed my DV from stock to a dahlback onethats when i noticed power loss right after i changed it could it be i pulled on a hose?? cause the one going up i kinda pulled on but i cant tell where it goes from on top of the car
Old Apr 14, 2008 | 10:06 AM
a41.8Tblk's Avatar
i guess i just have to get the car on a dyno and see whats wrong
Old Apr 14, 2008 | 01:22 PM
Bjk2's Avatar
problem with throwing it on the dyno is that you don't have any baseline numbers to compare it to...
Old Apr 27, 2008 | 07:31 PM
AudiTech616's Avatar
Sounds like you have a leak. Check the hosegoin into the turbo from the intercooler. That hose usually breaks. While the car is idling go underneath and move the hose goin to the turbo around. You should hear it leaking from around the wastegate.
lourinho1974
Aug 1, 2013 02:34 AM
steven.whyte
Mar 15, 2012 11:53 AM
tgsworldwide
Sep 10, 2008 07:37 PM
RedTTQ
Apr 23, 2007 06:44 PM
AudiZen
Aug 23, 2005 04:51 PM
