Help Identify Connector
Old Mar 17, 2017 | 07:32 PM
vrquick's Avatar
Default Help Identify Connector
I am in the process of re installing my engine and cant find were this connector needs to go. It is coming off the main wiring harness at the back firewall. If anyone has any idea that would be great.
Thanks
Attached Thumbnails Help Identify Connector-20170317_155033.jpg   Help Identify Connector-20170317_155039.jpg   Help Identify Connector-20170317_155042.jpg
Old Mar 18, 2017 | 07:49 AM
A4TurboGuy's Avatar
I'm sorry, but those pictures suck, Can you rotate them correctly before you post them. Also, put your car, engine and specs in your sig (like mine) so people know what you have. That will allow them/us to help you better/quicker.
Old Mar 18, 2017 | 03:36 PM
UberTeile's Avatar
The connector housing appears to be similar to part# 443-906-232, but it's green in color. After a brief check through ETKA, I can't find a 2-pin connector in that color so it's possible that it's replacement is now Black. That particular style of connector serves many different functions, so it's difficult for me to recommend exactly where it might go.
Old Mar 19, 2017 | 10:08 PM
elduderino200's Avatar
Is that the knock sensor? There's only a few connectors back there: knock sensor, front and back o2 sensors, crank position sensor... anything else?
Old Mar 20, 2017 | 12:59 PM
A4TurboGuy's Avatar
+1 The only other sensors in the back that I can think of are the coolant temp sensor (but it's too far from where your picture shows the harness to be). Also, the Vehicle speed sensor and the Cam speed sensor are not the same (2 different sensors) and again, as stated above, you have your crank sensor.
Have you run the car and then checked for codes, because my car has a harness that goes to nothing (some cars have options that others do not, yet they share the same harness).
G/L
Mankind121
Jul 9, 2007 06:34 PM
A4BlackBeast
May 12, 2006 11:16 AM
passatowner
Mar 23, 2006 06:54 PM
Daniel
Mar 6, 2003 01:31 PM
