help! my 96 audi a4 windshield washer wont spray!
Old Feb 23, 2012 | 11:43 AM
o0hmikee's Avatar
Default help! my 96 audi a4 windshield washer wont spray!
does anyone have a tutorial on how to fix an audi a4 b5 windshield washer? Mine wont spray but the headlight washer would work...now i was also wondering how can i delete the headlight washer system.
Thanks!
Old Feb 23, 2012 | 11:55 AM
M5S5's Avatar
Tech Certified
Thanks!
You could disconnect it electrically at the pump. As far as the windshield washers , first remove the hose from under the hood where it connects to the nozzle & try & activate. if you get fluid the nozzles are clogged & can be cleared with tiny wire.
If you have no fluid you would have to check the pump motor. Unfortunately the pump motors are in the washer bottle & it is buried inside the left front inner fender well. You will have to remove wheel , inner fender to access.
One more thing i forget to mention is that you have two separate washer pumps. If you find the one for the windshield is bad , swap it for the one for the headlights.
Old Feb 28, 2012 | 09:16 AM
o0hmikee's Avatar
thank you do you have a link on a tutorial on this? photos etc?
Old Feb 28, 2012 | 09:20 AM
M5S5's Avatar
Tech Certified
No.
Real simple. If you have to get to the washer bottle , remove left front wheel (after jacking the car up first) , remove all bolts & screws that hold the inner fender & remove from vehicle. The washer bottle will be in the front of the wheel well.
dlcain
B7 Models
Jul 24, 2014 12:06 PM
mcanedo92588
Jul 1, 2013 11:27 PM
snakeman01
Jun 29, 2011 07:49 AM
jj2345
May 13, 2007 10:36 AM
AvantGarde02
Feb 8, 2007 09:43 PM
