help! my 96 audi a4 windshield washer wont spray!
does anyone have a tutorial on how to fix an audi a4 b5 windshield washer? Mine wont spray but the headlight washer would work...now i was also wondering how can i delete the headlight washer system.
Thanks!
Thanks!
If you have no fluid you would have to check the pump motor. Unfortunately the pump motors are in the washer bottle & it is buried inside the left front inner fender well. You will have to remove wheel , inner fender to access.
One more thing i forget to mention is that you have two separate washer pumps. If you find the one for the windshield is bad , swap it for the one for the headlights.
No.
Real simple. If you have to get to the washer bottle , remove left front wheel (after jacking the car up first) , remove all bolts & screws that hold the inner fender & remove from vehicle. The washer bottle will be in the front of the wheel well.
mcanedo92588
Jul 1, 2013 11:27 PM
