Help ordering wheel bearing
Old May 8, 2012 | 01:23 AM
pbrules10's Avatar
Default Help ordering wheel bearing
I need to order the driver side rear wheel bearing. Do I need 2? Does the brand really matter? Which one should I order off of here - RockAuto Parts Catalog
Old May 8, 2012 | 01:33 AM
pbrules10's Avatar
What about this? Audi A4 Wheel Bearings - Audi A4 Rear Wheel Bearing Kit - Quattro
It seems to cheap to be good, but I have heard great things about blauparts.
Old May 8, 2012 | 07:07 AM
jonbonesjones's Avatar
Moderator
its a good idea to do both because if one failed due to age and wear the other one is not far behind its not like they are expensive or anything. blau ones are fine you won't have a problem
Old May 8, 2012 | 08:45 AM
redmond1501's Avatar
If you only get one, you'll be back buying another one within a month or two.
Old May 8, 2012 | 02:06 PM
morpheous's Avatar
Yeah,the fellas are right. I replaced my rear driver and passenger side,wheel bearings. My driver side was loud as hell,so i knew that one needed to be replaced.
I figured i should just replace both,being it would be not very long,for the passenger side,bearing to go.
It will save you money in the long run,not having to pay for someone to press the old bearing out and the new bearing in,twice at two different times.
Do it them both,at the same time.
Kyle_vdk
Jan 11, 2014 10:25 PM
audi guru
Jul 3, 2010 06:53 PM
A4PLAYIN
Aug 10, 2007 01:37 PM
