help pls.. air flow flap motor
Hi all. I have this fault code
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
anybody know where this part is exactly at? i read somewhere that its behind the glove box but that was for an 02 a4 not sure if its the same with us. Also a part number or a link where i can get it at will really help. Thanks guys. I'm running into numerous ac fault codes.
i have only found on for vw mk2s but its behind the glove box there seems to be a strap but once you can remove the glove box you are supposed to be able to see it. its just a matter of getting it out, anyone have a bently PDF right now this would be the time to use it. i highly doubt the shitty haynes has it but ill look later.
I found this but its for an 02 a4. I wonder if it would also be the same for my 01 a4. Watcha think?
http://www.audizine.com/forum/showth...problem-w-code
gun4hire
Jun 29, 2015 08:01 PM
