Help with tie rod end removal
Old Mar 2, 2018 | 10:46 AM
ProfileTrader's Avatar
Have you sprayed it (repeatedly - may be needed over several days) with a penetrating lubricant. Also you could try a ball joint separator (if you can get it to grip and hold). Where are you located (in regards to getting a new bolt) - I can make some suggestions, but your profile name shows a UK email.
Old Mar 2, 2018 | 11:00 AM
jcattermole@hotmail.co.uk's Avatar
Hi,
Many thanks for such a quick reply. I will as you suggest repeat use of the penetrating oil over several days. My other alternative is to drill it, but concerned I might do further damage by straying into the alloy arm. Yes, I am in the UK and I am guessing you are in the USA. Do you know what length and gauge and quality of steel is used in the bolt and I shall go to the local ironmongers and get a suitable replacement. Funny thing is I have just changed one on my much older Mazda MX5 and it was easy and without incident.
Old Mar 2, 2018 | 11:13 AM
Do you have any Audi dealerships nearby. In the US they are more expensive - but for a bolt or two it really doesn't set you back too much.. and in a pinch (pun intended) it is worth it.
You can also go here to get info on parts.. For the pinch select the front axle/steering after selecting the year/model of your car.
https://nemigaparts.com/cat_spares/etka/audi/a4/
Old Mar 2, 2018 | 11:54 AM
Soley4pres
Jul 11, 2011 11:58 PM
99a4wagon
Dec 10, 2010 07:03 PM
halfmoonclip
B8 Models
Jan 9, 2010 09:48 PM
nhltfour
Apr 22, 2007 02:23 AM
MeanAudiA6
Aug 6, 2006 04:57 PM
