VCDS-Lite Version: Release 1.2
Tuesday, 16 April 2013, 11:19:02.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: 078-907-551-ACK.LBL
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D04
Coding: 06251
Shop #: WSC 06335
VCID: 6CAB47B30F93
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16825 - Shareware Version. To Decode all DTCs
P0441 - 35-10 - Please Register/Activate - Intermittent
18014 - Shareware Version. To Decode all DTCs
P1606 - 35-00 - Please Register/Activate
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18032 - Shareware Version. To Decode all DTCs
P1624 - 35-10 - Please Register/Activate - Intermittent
17879 - Shareware Version. To Decode all DTCs
P1471 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8D0 927 156 BQ
Component: AG5 01V 2.8l5V USA 8511
Coding: 00000
Shop #: WSC 00000
VCID: 7D8D7AF764E9
3 Faults Found:
00532 - Supply Voltage B+
39-10 - Output won't Switch or Short to Ground - Intermittent
18265 - Shareware Version. To Decode all DTCs
P1857 - 35-10 - Please Register/Activate - Intermittent
00526 - Shareware Version. To Decode all DTCs
27-00 - Please Register/Activate
Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D54
Coding: 00160
Shop #: WSC 06335
VCID: 2B2984AFCA1D
4 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
00779 - Shareware Version. To Decode all DTCs
30-00 - Please Register/Activate
01273 - Shareware Version. To Decode all DTCs
17-10 - Please Register/Activate - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Coding: 06251
Shop #: WSC 06335
VCID: 6CAB47B30F93
6 Faults Found:
Coding: 00000
Shop #: WSC 00000
VCID: 7D8D7AF764E9
3 Faults Found:
Coding: 00160
Shop #: WSC 06335
VCID: 2B2984AFCA1D
4 Faults Found:
ok guys so after i cleared the codes and drove it for a while i got the maf sensor is bad code again, and the tranny had a code that said error message from ecu, so im guessing my maf sensor is bad and its causing the tranny to go into limp mode, can anyone confirm this for me i would really appreciate it but im almost positive that this is what the problem is, because when my check engine turned on the tranny went into limp mode right away...
Category:Fault Codes - Ross-Tech Wiki
This is the website where you can look up all the numbers, and decipher what they mean.
00532 - Ross-Tech Wiki
18265/P1857/006231 - Ross-Tech Wiki
00526 - Ross-Tech Wiki
Those are all your transmission code links. The 18265 code is the one that is troublesome. It says check ECU for stored fault codes. So I would agree that your MAF might actually be causing your transmission to jump into safe mode. The transmission is only receiving that code when your engine is throwing a fault code at the ECU, and it has to be a specific code at that. That's my two sense man. Anyone with better input feel free to chime in. Your logic is sound though.
guys i just wanted to bring this back and say that it was my maf sensor i changed it and have driven about 200 miles and limp mode hasnt come back, i wanted to thank snickelsnizer for the help and this is why we have this forum a 25 used sensor and a 10 dollar amazon wire fixed a potential problem that couldve cost me hundreds thanks again!!!!!
Thanks for this write up, I'm having a similar issue, however, my problem was that the car wouldn't stay running unless the rpm was over 1000. I changed the MAF and threw on a short ram intake, and now it won't run if I get over 1000 rpm (atx 98 2.8 A6).
I have a P1857 error from ECU and I'm also getting a "MAF Signal low" code as well.
Could I have gotten a bad new MAF sensor?
