here are some codes.... need help
Old Feb 22, 2009 | 01:27 PM
brooklands204's Avatar
Default here are some codes.... need help
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
Old Jun 17, 2009 | 10:55 PM
stac104's Avatar
You need to replace all of your coil packs, your catalytic converter, and both of the 02 sensors attached to your exhaust system.
Old Jun 18, 2009 | 01:31 AM
Tweaked's Avatar
Hahahaha you can't just assume that from those codes! That's some seriously expensive shot-gun, part-swapping diagnosis!
What year and engine is the car?
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
