high mileage
ok so i have a 96 b5 a4 and it just hit 98000 miles. and a In1 signal turns on when i turn the car on. i kno it means i have to get the car inspected but what is the usual maintenance at this mileage?
5,000 miles
Engine Oil: Change Oil
Engine Oil Filter : Replace the engine oil filter
Wheels: Rotate front to rear
Fluid Levels: check all fluid levels
Automatic Shift Lock: check operation ( Automatic transmission only)
Brake System: check pad thickness and brake fluid level
Manual Transmission: check gearshift and clutch for proper operation
10,000 Miles
Cooling System: check coolant level
Exhaust System: check for damage and leaks
Engine On-Board Diagnostic: check trouble code memory
Doors: lubricate hinges
Battery: check electrolyte level
Windshield wiper and washer: check fluid level, add fluid if necessary
Tires and spare wheel: check for wear and damage, adjust pressure
Brake System: check for damage and leaks, check thickness of pads and fluid level
Drive Shafts: check the boots
Road test: check braking, kick down operation ( automatic transmission only), electrical, Heating and ventilation systems, air conditioning, and power accessories
Lights: check the lights
20,000 Miles
Engine: check for leaks
Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends
Automatic Transmission : check for leaks
Manual Transmission : check for leaks
Manual Transmission Final Drive: check fluid level
Dust and Pollen Filter: replace filter
Headlights: inspect headlights
Sliding Roof : clean guide rails, and lubricate
30,000 Miles
40,000 Miles
Power Steering Fluid: check fluid level
Air Cleaner: replace filter element
Spark Plugs: replace the plugs
60,000 Miles
80,000 Miles
100,000 Miles
120,000 Miles
140,000 Miles
Josh
10,000 Miles
20,000 Miles
30,000 Miles
40,000 Miles
60,000 Miles
80,000 Miles
100,000 Miles
120,000 Miles
140,000 Miles
Josh
