High mileage A4's check in!
Old Mar 19, 2014 | 12:20 AM
  #51
Jeremy Decker's Avatar
1998 A4 1.8T Quattro just hit 165K
Old Mar 30, 2014 | 02:45 AM
  #52
AFReg's Avatar
Just got a 2000 A4 with a 1.8t auto, she has 154k and is in pretty good shape. Glad to see they can handle the miles fairly well.
Old Jun 17, 2014 | 10:30 AM
  #53
GreenMachine22's Avatar
I just hit 191k, not nearly as high as some of you. Just replaced front rotors and brake pads, need to do rear. Replaced one CV axel need to do the other. Clutch put in about 20k ago. Turbo went out so I replaced it with a bolt-on k04. Runs like a dream but I am worried about upping the boost because the engine has that many miles. Havent changed anything since the new turbo but I did put a bleed on the wastegate to allow 10 psi of boost. Is it safe to increase boost? Any suggestions on maintenance to keep engine mechanically sound?
Old Jun 19, 2014 | 03:54 PM
  #54
nomadzx4's Avatar
295,000k..96 a4 2.8 quattro..still pulling strong...needs a wheel bearing and blower motor
Old Jul 28, 2014 | 02:26 PM
  #55
Iguana6699's Avatar
Default 420,000 Kms AHA B5
I drive a 98 2.8 Quattro daily. 420,000 kms. About 260,000 miles. Engine, clutch, trans all original as far as I know. Still pulls great and has been through 15 Canadian winters with no rust.
Old Jul 28, 2014 | 02:29 PM
  #56
mtroxel's Avatar
260K and original clutch? That makes me feel good. My "young" 210K car has the original clutch and I've been expecting it to crap out on me.
Old Jul 28, 2014 | 02:44 PM
  #57
GoremanX's Avatar
If it was bought in spring 1998 or later, then that's 16 winters. If it was bought near the end of 1997, then that's 17 winters.
Yes, I counted that out using my fingers
Mine's got all kinds of rust cancer on 3 body panels after just 13 Vermont/Quebec winters (left fender, hood, hatch). I really wish it was rust-free.
Old Jul 28, 2014 | 02:46 PM
  #58
GoremanX's Avatar
My original clutch has been "due" since 220k miles, but at 255k miles, it's still holding on.
Old Oct 29, 2015 | 10:27 PM
  #59
GoremanX's Avatar
Another update: 276,000 miles with the original head gasket on the original engine and the original clutch. I drive it hard almost every day.
Engine is getting tired though. Rings are worn, valve guides are leaky and the turbo doesn't spool up like it used to. I'll be replacing the engine altogether in the next month or two with a new engine I built from the ground up. Guess I'll have fun rebuilding this one once it's out.
Old Nov 12, 2015 | 01:20 PM
  #60
green2man0's Avatar
1997 Audi a4 1.8t couple hundred away from 200k. Bought with a broken trans...so the only big stuff is the transmission clutch and flywheel being replaced. But there has been lots of little stuff...still for 5k including the new clutch/trans/flywheel It's never left me stranded in 8 years
