Horn and cig lighter not working - please help
Old Jun 6, 2008 | 09:45 AM
youngturky's Avatar
Default Horn and cig lighter not working - please help
Hi my horn and my cigarette lighter stopped working. I think it might be my fuses but the problem is I didn't get an owner's manuel sodon't knowwhich fuses to replace. So canmaybe someonescan the page on the owners manual or possibly direct me to a website.
so thanks for your help if you do help me
Old Jun 6, 2008 | 10:07 AM
cantdrive55's Avatar
Default RE: Horn and cig lighter not working - please help
If you remove the fuse panel cover on the drivers side you will see on the insde of that panel everything is listed where it is and what fuse it takes.
Old Jun 8, 2008 | 10:19 PM
jiggleo's Avatar
if you're missing that sticker try buying a $5 test light and that'll tell you if any fuses are blown.
Old Jun 10, 2008 | 03:52 PM
a4track2's Avatar
or you can just pull one out check them one by one and see if it is blown. but the good thing about a test light is its faster and always good to have one. Plus if s says there not blown then you can cancel the fuse panel out of the problem. but it sounds like its your fuses.
Old Nov 9, 2008 | 06:13 AM
05avant_miked's Avatar
Originally Posted by CCA4
Ok here ya go. I know I said I was gonna have this for you last night but some sh*t came up, sorry man. I'm gonna list them the way they are in the owner's manual:
1-Headlight washer jets
2-Turn signal flasher
3-Headlight washer, glove box light, engine bay light, instrument cluster
4-License plate lights
5-Instrument cluster, heated seats, auto trans display, outside air temp
6-Central locking system
7-ABS
8-empty
9-heated mirrors
10-empty
11-cruise control(auto trans)
12-on board diagnostic system
13-brake lights
14-interior lights
15-power windows, climate control
16-ABS, anti-slip(?)
17-heated door locks
18-right high beam
19-left high beam
20-right low beam
21-left low beam
22-tail and side marker (right)
23-tail and side marker (left)
24-wipers and washer jets
25-blower for heating/climate control
26-rear window defogger
27-empty
28-fuel pump
29-engine timing
30-sunroof
31-tail lights, cruise control, auto trans
32-engine timing
33-cig lighter
34-engine timing
35-trailer receptacle(?)
36-fog lights
37-radio
38-trunk light, central locking system
39-flashers
40-horn
41-empty
42-empty
43-heated seats
Ok theres the numbers. To figure out what the hell that means you have to look at the inside of the cover to the fuse box. Like Andrew said its very very faint. Good luck!
here is another thread for the b5 fuse layout..
look at my post about my horn and cig lighter not working..
just went thru it myself
Old Jan 19, 2009 | 09:17 AM
davey_g78's Avatar
Is this list the same in the 1.8T?
redlineq5
Nov 19, 2013 12:17 PM
King_Life
Dec 5, 2012 09:09 AM
audi809
Oct 30, 2008 05:47 PM
budnfrida
Jul 9, 2006 06:00 AM
kpatz
Apr 17, 2006 03:42 PM
