hose clamp on outer CV boot
Old Apr 19, 2008 | 09:25 AM
heloman28's Avatar
Default hose clamp on outer CV boot
...so I just replaced th outer boot on the pass. side front axle. Was great for a month, but the outer clamp let go and the joint started spraying grease all over the place again. Tried the universal boot clamps= POS, and finall said f**k it and used a 6" hose clamp. Cut off the excess band, dremeled it down to take off the sharp edges, and voila! it works. Has anyone tried this or know if it will stay tight? I have a feeling that the centrigual force is gonna loosen the tightening screw, even thought in foward motion the screw will be turning clockwise= keeping it tight. Any thoughts?
Old Apr 19, 2008 | 09:33 AM
ImTheDevil's Avatar
Default RE: hose clamp on outer CV boot
Put a blob of JB Weld on the screw at each end (on the head and on the tip), and use enough to bond it to the sleeve that it threads through. That'll hold it just fine.
JoshandDawn
May 22, 2011 05:18 PM
oneg
Sep 9, 2007 01:26 AM
B5luver
Apr 3, 2007 09:44 PM
BCFD3S
Aug 16, 2006 04:45 AM
peccin
Jun 29, 2005 02:43 PM
