How do I get the radiator hose off?
Old Feb 3, 2009 | 07:49 PM
kpgeary's Avatar
Default How do I get the radiator hose off?
I have a 2000 A4 2.8 Quattro w/Auto and I'm in the middle of a timing belt job. I'm having a problem disconnecting the hoses from the radiator. I see the metal clips and I pulled them back, but the hoses aren't budging. I tried to pry the upper hose off with a screwdriver and the plastic started chipping. Any tips on how to get this off? It's supposed to be a quick release right? Thanks in advance.
Old Feb 3, 2009 | 08:08 PM
rallyaudi28's Avatar
Ya it should pop off with a very hard yank. There is a o ring in there that likes to seal real well. When I took mine off I thought I was going to brake it with how hard I had to pull it.
Old Feb 3, 2009 | 08:13 PM
MARKANTO13's Avatar
Default getting off the radiator hoses
try spraying them w/ penitrating fluid like PB Blaster and turn them as you pull them off.
Old Feb 3, 2009 | 08:14 PM
kpgeary's Avatar
Thanks! I'll go try again.
Old Feb 3, 2009 | 08:24 PM
somebody5788's Avatar
If you wiggle the hose around and twist a little it should pop right off. I haven't had an issue yet.
Old Feb 3, 2009 | 09:10 PM
ImTheDevil's Avatar
Yep - it takes some twisting and swearing and it can be a real mother to get off there, but it will come off. It's a pain, but that's good really - not likely that it'll ever just pop off while you're driving.
Old Feb 4, 2009 | 09:00 AM
kpgeary's Avatar
Thanks again for all the replies. I shot it with some penetrating fluid and let it sit over night. The next morning it came off with little resistance.
FinmanA6
Oct 25, 2010 02:08 PM
moeron7
May 19, 2010 12:07 PM
Rockpundit
Dec 17, 2008 08:59 AM
teranenrique
Jul 24, 2007 09:12 PM
mrdb85
Nov 27, 2006 01:37 AM
