How to replace MIL bulb
Old Dec 4, 2010 | 12:18 PM
vtraudt's Avatar
Default How to replace MIL bulb
I ran output test with VAGcom, and MIL light does not come on.
I am guessing the bulb is bad.
I could not find anything in Bentley that shows how to replace bulb.
Are there detailed instructions out there?
Old Dec 4, 2010 | 10:32 PM
Dallas09's Avatar
Does the service engine light come on when you turn the car to on? If it doesnt and the car runs fine, then to remove the cluster you remove the trim in between the cluster and the steering column by pulling it (u-shaped piece) and there are two torx screws. Pull the cluster out a little ways and disconnect the connectors (there are little flip lock things that hold them on, youll see), then pull the cluster out and you will expose the bulb holders.
mb2audi
Nov 29, 2010 07:59 PM
suey
Jul 25, 2009 11:59 PM
mnets
Feb 17, 2008 12:05 PM
gillfish
Feb 26, 2007 04:27 PM
dudley doright
Oct 4, 2004 06:44 PM
