How to run 0 awg for my amp?
Old Apr 1, 2010 | 02:22 AM
Nevalite's Avatar
Thanks cybersombosis, I'll take a look there.
Old Apr 1, 2010 | 08:03 AM
99A4NOW's Avatar
I'm just curious to know, what for alternator are you going to upgrade to? I'd like to bump mine up to 150 amps or more, and I'm figuring you're going to need at least that to run those amps, and I'd like to know more about what bolts up to the A4 without much trouble. Thanks!
Old Apr 1, 2010 | 08:52 AM
dragonrage's Avatar
Your alternator can't come close to keeping up with 0 gauge, so don't bother going bigger than 2 gauge unless you're upgrading that.
BTW, www.weldingsupply.com for wire.
Old Apr 2, 2010 | 01:40 PM
Mike-2ptzero's Avatar
On your 2000 you can drill out the Triangle opening that is not used on the 2000 but is used for the throttle cable on a ndbw car. It is located right in the center of the car next to the battery. This is where I ran my wire back when I was running 3 JBL amps.
Old Apr 2, 2010 | 01:46 PM
209AudiGuy's Avatar
this is the same location i used for my 2 4agw wires i ran for my zapco amps
Old Apr 4, 2010 | 12:48 PM
Nevalite's Avatar
Do either of you guys have a pic of that location? The one beside the battery? Because I cant seem to find it... Do I have to move the battery?
The only location I can find is the one behind the ECU... -_-
Old Apr 4, 2010 | 01:04 PM
Someone already posted a picture of it for you. You just need to remove the windshield wipers and the covers below them to really see it and to work on it.
It is inside the red circle which is just to the left of the brake/clutch fluid tank.
The 2 red circles are where the stock Throttle Cable runs on the ndbw cars.
Old Apr 4, 2010 | 01:58 PM
  #18
Nevalite's Avatar
Oh ok you guys were both talking about the same spot. Yeah I just looked there and that seems like a great spot to run the wire. I think the 0awg is a bit big but I can modify it.
I'm afraid the edge is going to cut into the wire creating a mega short. What did you guys use to protect the wire going through there?
Thanks
Old Apr 4, 2010 | 02:01 PM
  #19
You will need to make that hole bigger, you can then put a rubber grommet in it and then the wire.
Old Apr 4, 2010 | 02:28 PM
  #20
Nevalite's Avatar
Yeah I'll have to do some dremel work there. Where could I get a grommet like that locally? Home depot?
Also what do you think of using the hole where the AC unit goes?
AC.jpg?t=1270402533
Any danger in that?
