http://www.headlighthaven.com
Old Jun 8, 2012 | 11:10 AM
MetalMan's Avatar
Originally Posted by morpheous
So you're saying,the reason the passenger side bulb is white,is because it is bad? what about the light,cutting off at random,times?
So what if i swap the bulbs and the problem,follows the bulb from the driver side?
Whenever I've had HID bulbs that cut out it's because the ballast is bad. In fact I just replaced one of my ballasts about 3 weeks ago because the bulb would sometimes flicker on/off or just not even turn on.
The bulb being white doesn't necessarily make it bad, it might just be a different color temperature than it should be. But when you try swapping or replacing that bulb you'll know for sure.
Old Jun 8, 2012 | 12:39 PM
ImTheDevil's Avatar
The shift in color temp is achieved by putting different concentrations of sodium in the bulb. As the bulb's life progresses, some of the sodium is consumed and the bulb color will change.
DraxeofDclan
Oct 14, 2009 09:36 PM
1.84life
May 8, 2008 11:23 AM
1.84life
May 7, 2008 03:45 PM
techbod
Jan 27, 2008 09:15 PM
