Hubcentric rings
Old May 27, 2012 | 05:30 PM
Sheasta's Avatar
Default Hubcentric rings
So as some of you may have mentioned in my other thread ill most likely need hubcentric rings. You were right. Wheels bores way bigger. Very noticeable on the highway. I have the wheels on the car now without the rings. Will cause any damage? Do i want metal rings or are plastic fine? Should i order em online or can i just buyem somewhere?
Old May 27, 2012 | 06:31 PM
ImTheDevil's Avatar
Probably online will be cheaper and plastic is fine. As for running without them, be very careful - its easy to mount them slightly off center, which can stress and break them. Happened to me with the Volk AV3s I ran on my 300ZX. You're best waiting til you get the rings though.
Old May 27, 2012 | 06:36 PM
Sheasta's Avatar
Theyre already on the car and the stock wheel tires bald/ leaking. I guess ill just order them asap and hope for the best. Thanks.
Old May 28, 2012 | 03:05 PM
Sheasta's Avatar
Sooo can I find the wheels hub specs anywhere inside the rim or anything online? Or do I have to measure it? I dont have a vernial caliper or anything like that unfortunately.
Old May 28, 2012 | 03:15 PM
CCA4's Avatar
Stock hub bore on a B5 is 57.1mm. You're gonna have to figure out the bore on your wheels though. Where did you buy them? What brand are they? Can you take a pic of the inside of the center section of one of the wheels.?
Old May 28, 2012 | 04:05 PM
Sheasta's Avatar
I bought them on craigslist. They are 17x8 BBS Moda Sports. I guess Ill take one of them off and take a pic. Such a pain in the *** to line it up without the rings though lol.
Old May 28, 2012 | 04:51 PM
Sheasta's Avatar
Forgive my retardedness. The guy gave me these with the wheels but i think my lugs were to short to tge wheel and these on or just forgot i had these. he said they were spacers. Name:  0898b251.jpg
Size:  185.6 KB Name:  f5a137ec.jpg
Size:  155.8 KB Name:  d8443e9e.jpg
Size:  98.8 KB Name:  b61455f2.jpg
Size:  106.8 KB Name:  9d29e00a.jpg
I know hubcentric rings are supposed to be more like this : http://www.google.com/imgres?imgurl=...PUBMAY&dur=367
But these look almost like adaptors and spacers combined? Or am I just confused and if you get spacers you dont need rings? Im new to all this stuff so any help would be appreciated. Do I need longer wheel lugs/bolts to put these on?
Thanks, Sheasta
Old May 29, 2012 | 01:15 AM
Sheasta's Avatar
bump. Need this sorted out.
Old May 29, 2012 | 03:18 AM
NickBroderick's Avatar
Those are hub centric/wheel centric spacers. Looks to be about 10mm, get some extended bolts if you want to run those.
Old May 29, 2012 | 02:17 PM
Sheasta's Avatar
Ok thanks. So I should just go to like advance auto or something like that and ask for extended bolts.
