HYDRAULIC CLUTCH PROBLEMS?
Old Mar 30, 2008 | 09:33 PM
bolob5's Avatar
Default HYDRAULIC CLUTCH PROBLEMS?
Well I have been having a problem with my 97 for awhile now and need some help. Whenever I depress the clutch in the morning and let it out to catch first or reverse, there is a loud hissing/swooshing noise. It only does this on the first engagement every single time but then it stops... I had the clutch replaced this weekend -everything- and it still makes the noise. The hydraulic system had no leaks and the fluid looks good. It sounds to me like the clutch master cylinder might be going out or the slave needs to be replaced but I am at my wits end. Any help would be much appreciated... Thanks
Old Mar 30, 2008 | 10:18 PM
01AudiA4's Avatar
Default RE: HYDRAULIC CLUTCH PROBLEMS?
I think the clutch master cylnder is the same as the brake...
Old Mar 30, 2008 | 11:59 PM
SAudi's Avatar
the the clutch cylinder is above the tranny or all incased in the bell housing it usually inspected and or changed when a clutch job is done. im really freaking tired now and probably talking out of my @$$ but what do you mean hissing, like a loose air hose or mechanical sounding. also any difference in the fell of the clutch or drivability.
Old Mar 31, 2008 | 08:38 AM
bolob5's Avatar
Further Detail: the noise is like opening a Coke can. Every first engagement,,, when the car has been sitting for awhile. Coming from the driver side, around the firewall... HELP!!!!
Old Mar 31, 2008 | 06:24 PM
bolob5's Avatar
Well I will be checking all of the vaccum lines and the slave tonight. Hopefully someone can add some bit of advice...
Old Mar 31, 2008 | 08:48 PM
bolob5's Avatar
Well I'fingered' the PCV this afternoon and the T joint was blown apart. I think I just found the hissing/swooshing sound...
TallahasseeTT
Sep 9, 2010 03:02 PM
chocalotstarfish
Jun 29, 2010 09:43 PM
Hornet99
Oct 7, 2005 05:18 AM
SamJamaica
Jun 13, 2005 02:07 AM
