Hydrolic leak fix?
Old Jan 13, 2009 | 03:35 PM
zchb9's Avatar
Default Hydrolic leak fix?
I got a small hydrolic leak. My dad suggested getting the lucas power steering fluid leak stop and putting in it to try to fix it. I'm kinda iffy on this idea. Do you think it will work or just mess something else up?
Old Jan 13, 2009 | 03:59 PM
CCA4's Avatar
The purist Audi guys on here will tell you never to add anything to any of the fluids in these cars, they tend to be very tempermental. If its a bad leak i would suggest fixing the root problem rather than just trying to make it go away. If its not that bad then I don't think I'd risk gumming up the PS components with StopLeak.
So in a nutshell, no.
Old Jan 13, 2009 | 05:13 PM
onepoint8tee's Avatar
"Purist"... Thats a good way to put it! So true. Baby boomers can be so naive (no offense, dad.) Hole sealing additives might work for a small leak, but when you do get around to actually fixing the problem after it gets worse down the road, you have created a more of a mess to clean up/flush out than the temp fix was worth.
caliiangel
Aug 5, 2012 01:19 AM
dj_jalland
May 11, 2011 08:22 AM
bshannon1
Jun 2, 2009 12:19 PM
gregp1962
Mar 1, 2007 03:34 AM
klum00
Jul 26, 2006 08:15 PM
