I found out how to fix my ICM forever!!
So after reading many stories of people having trouble with their icm causing misfires I was devastated when my cel came on with random misfires. So instead of either paying to replace the icm, or deleting the icm and putting in new coils I decided to try something I've never heard of anyone trying before.
I have a background of fixing computers/xboxs for some extra money, I learned many things through doing this but one thing I learned helped me fix my icm (2k miles later and the cel hasn't returned). For those of you that don't know, the icm has a heat sink inside the stock airbox, the icm is screwed done to the heat sink with a thermal paste in between the two, basically what I decided to try is to remove all the old paste and put on new artic silver 5 which Is a higher quality paste originally on there. Thermal paste breaks down over time when introduced to the conditions inside the engine bay (extreme heat, moisture, etc.).
It cost around $10 and less then 10 minutes. If anybody is interested I can write up how do it (I would also recommend this as a preventive measure)
You're right that it won't be a universal fix but hopefully it will save atleast a few people from spending $150+ on icm delete or $75+ for a new icm
Normally if it is already broken then it will stay broken, but as a preventive measure it should save some people
Normally if it is already broken then it will stay broken (i probably just got lucky). But as a preventive measure it should save some people
