idk if this is right.......
Old Aug 8, 2008 | 01:07 PM
audikiller09's Avatar
Default idk if this is right.......
I have a 1997 A4 1.8t fwd 5 speed and for mods i have a straight pipe exhaust, a home made CAI, some E3 spark plugs, and lowered with tien S-tech...the car weighs 3050 with the driver...so recently i went to awe tuning and got the chip done and i was told i should run atleast low 15's in the quarter mile.....so i went to the track and my best run was a 15.99 at 85 mph. does this sound right? i was really hopin for the 15 flat......is there any other affordable mods that i could do in the mean time? thanks
Old Aug 8, 2008 | 01:14 PM
auditech79's Avatar
Sounds like you need to work on your clutch work.
Old Aug 8, 2008 | 01:25 PM
clutch meaning upgrading it or my driving skillz?
Old Aug 8, 2008 | 01:33 PM
cincyTT's Avatar
I'm make believe
Yes, your probably not shifting fast enough or launching at the right rpms.
Old Aug 8, 2008 | 01:34 PM
auditech79's Avatar
Thats what i mean, un-less your clutch is just flat out slipping.
Old Aug 8, 2008 | 01:40 PM
what is a good way to figure out if my clutch is slipping? if it isnt what rpm should i launch at? and should i put my stock airbok on or keep the CAI? nd would it be worth it if i invested in a short throw shifter?
Old Aug 8, 2008 | 01:48 PM
cincyTT's Avatar
I'm make believe
if you clutch was slipping, you would know. The rpms would increase as you go no where. Try launching at ~3k since you are fwd. Intake doesnt matter. A short throw couldnt hurt, you can get an ebay one that is good quality for cheap
Old Aug 8, 2008 | 01:51 PM
so just pop the clutch at 3k?
Old Aug 8, 2008 | 02:42 PM
ImTheDevil's Avatar
Yep - it's a good place to start. You'll need to experiment to come up with the right technique for your car. What works for me may not work for you - different tires, track prep, suspension condition, etc all weigh into the results.
