idle jumping, check engine light, and bogging
Old Jul 7, 2008 | 01:15 PM
wanteda4's Avatar
Default idle jumping, check engine light, and bogging
I have a 1999 a4 1.8t and my brother took it to MN from WI. I got my keys back this mourning and took it out for a drive. I look at the tach and the rpm idle goes from 900 to 400 then increases to 1400 and settles down at 800. I took it out for a drive to see. I hit the gas it bog and feels like its going to shut off but then it goes. I shift and gas it again and it bogs.the check engine light is also on and my car louder now. my brother told me, they were driving and the check engine light came on. i am clueless as to what is causing this. help please.
Old Jul 7, 2008 | 02:09 PM
steezybme's Avatar
Default RE: idle jumping, check engine light, and bogging
Go to advance auto or autozone tell them to read your car and then post the code back on here... Someone with vag-com will let you know exactly whats the problem instead of jumping around to different things...
Old Jul 7, 2008 | 10:30 PM
audiltr's Avatar
is the check engine on or flashing
Old Jul 7, 2008 | 10:32 PM
Audi_Skydiver's Avatar
Does it have any trouble starting?
Josh
Old Jul 7, 2008 | 10:35 PM
audiltr's Avatar
if it flashing that means your having reatime missfire. this could be as easy an cheapas a coil or it could be your spark controll mod. just as easy but a little more expspensive let us know. hope this in was helpfull you still need to have the codes pulled it may have jumped time
Old Jul 7, 2008 | 10:36 PM
ghost6303's Avatar
it sounds either like you have a misfire, or more probably (because you said its louder) you have a leak somewhere after the mass air sensor and the TB. check the hose going from the intake piping to the diverter valve. on my car that hose is rediculously close to the A/C belt and it rubs thru the hose every now and again. i zip tied it out of the way to somewhere on the radiator.
Old Jul 7, 2008 | 10:42 PM
I think it's your coolant temp sensor. It can cause ALL kinds of problems, including misfires. I would try buying the CTS, it's like $10-$15 from the dealer and its an easy fix. Try that out first.
Josh
P.S. Also get the codes first.
Old Jul 8, 2008 | 01:11 AM
wanteda4's Avatar
thanks guys you guys are really helpful I'll go to advance tomorrow and get the codes.
Old Jul 8, 2008 | 01:04 PM
wanteda4's Avatar
ok I got the codes they are:
p1127-Manufacturer control fuel system metering
p1545-Manufacturer control veh speed Idle speed control
ajeepjeep
Sep 6, 2013 02:21 PM
John853
Dec 28, 2011 11:05 PM
shaztee4life
Jul 13, 2011 01:45 PM
OnlystreetraceAWD
Dec 10, 2008 12:18 AM
Willfulone
Apr 7, 2006 02:11 AM
