Idle/Tick-over Problem
Old Jun 8, 2013 | 12:18 PM
Kopper's Avatar
Default Idle/Tick-over Problem
My A4 1.8T B5 (1995) has a problem when idling, the revs bounce up and down below the 1k for a while before it settles at 900, this happens whenever I put the clutch in approaching a set of lights etc or when parked in neutral, can anybody give me some insight as to what is causing this? I had this problem on a previous car and somebody suggested the air-flow sensor?
Old Jun 8, 2013 | 01:22 PM
Pbcrazy's Avatar
A good first step would be to remove your mass air flow sensor and clean it. Any codes?
Old Jun 8, 2013 | 03:35 PM
markymarc's Avatar
Unplug the MAF and see if your car runs better.....or the same....if it runs better, there's your issue....
Old Jun 8, 2013 | 06:50 PM
Kopper's Avatar
Old Jun 9, 2013 | 11:23 AM
Kopper's Avatar
Where is the MAFS located? How can I get to it? Any specific tools that i'l need too?
Old Jun 9, 2013 | 02:15 PM
markymarc's Avatar
MAF sensor is easily cleaned or replaced. It's 1 connector, and four 10mm nuts (as I recall). You will need to remove the top of the air filter, and remove the plastic housing/tube that goes into the MAF, but apart from that it should be a 10min job...then clean it with electronics cleaner, there's a little filament in there...
Also check all your vacuum hoses for leaks etc...
mz3bo
Oct 18, 2014 07:26 PM
frizzlefry
Jan 28, 2011 03:07 PM
nmocci
Nov 4, 2008 01:59 PM
ezlnh8u
Sep 23, 2007 12:36 PM
slee22
Dec 4, 2004 03:18 PM
