installing my test pipe today
Old Jul 13, 2012 | 09:38 AM
ThatRetardedKid's Avatar
Default installing my test pipe today
so I'm installing my test for today and I'm wondering if this will O2 sensor spacer will work
Old Jul 13, 2012 | 09:42 AM
Also I heard that once it's on you smell straight fumes on the cabin
Old Jul 13, 2012 | 10:17 AM
jonbonesjones's Avatar
Moderator
threads look different. fine vs coarse. whatever the case you could probably crank it in there
Old Jul 13, 2012 | 10:24 AM
CCA4's Avatar
The exhaust will smell a tad more because you're removing the cat, but it's not going to stink up the cabin. The O2 sensor spacer I have is about twice as long as that one and it works very well. They can be had from RAI, 034, and eBay
Old Jul 13, 2012 | 10:39 AM
MetalMan's Avatar
I put a test pipe on a few days ago (to attempt to diagnose a clogged high-flow cat) and this morning with the driver window halfway down I definitely smelled exhaust when stopped at a light. But then again, my car creates more exhaust than yours does most likely, due to upgraded turbo and fueling.
Old Jul 13, 2012 | 11:11 AM
metal man is the smell unbearable and is the o 2 sensor spacer too small? BTW it fits perfectly. I just don't want it to be a gas chamber inside you know its an audi
Old Jul 13, 2012 | 11:14 AM
CCA4's Avatar
Make sure you use anti-seize between the spacer and the bung and the sensor and the spacer.
Old Jul 13, 2012 | 12:41 PM
OK thnx cca. Someone told me that the hole is too small in the spacer for it to work
Old Jul 13, 2012 | 02:15 PM
MetalMan's Avatar
Just to be clear, you're planning to put that spacer at the downpipe-end of the test pipe, not the turbo-end of the test pipe, right?
You can always try it out, won't hurt anything. The worst that will happen is you'll get a CEL light for the post-cat O2 sensor.
Old Jul 14, 2012 | 08:53 PM
Test pipe is in the hard part was the bottom side as for the spacer it went perfect just had to drill a bigger hole in the spacer and no CEL
Bigdog7373
Mar 25, 2012 09:47 PM
Mr. Phil
Feb 22, 2011 09:03 PM
bemor187
Feb 19, 2008 08:27 PM
azaky
Feb 20, 2007 12:34 PM
greenday
Nov 29, 2005 03:43 PM
