Instrument cluster not working
My instrument cluster quit workin all together. No backlighting no odometer, clock LCD, tach, speedometer, or gauges, nothing. Car runs fine. I stopped at the gas station and when I came out nothing worked. Any ideas?
I checked all fuses, all good, Removed and reseated plugs on back of cluster and checked wires couldn't find anything wrong.
2000 A4 1.8t Quattro.
I checked all fuses, all good, Removed and reseated plugs on back of cluster and checked wires couldn't find anything wrong. 2000 A4 1.8t Quattro.
there is a DIY on removing the cluster, it's not hard to do, I think it's like 2 torx screws or so , pull steering wheel all the way out and tilt down....your plug may have just fallen out of the back of it...
Instrument cluster removal and clean up..........DIY - AudiWorld Forums
You can send it out and have it rebuilt to keep your odometer reading correct, or buy a different one (it will have different odometer reading), however, I believe any cluster with mileage over 10,000 can't be recoded, but I don't exactly remember. And I see you are in Germany....
I'm going to guess you checked for loose wiring behind the cluster etc...see if anything got loose under/behind the dash?
asutherland
Jan 22, 2010 09:58 AM
1998, 28, a4, audi, b5, cluster, dash, gauges, instrument, quattro, speedometer, stoped, tachometer, working
