Intercoolers
Old Mar 1, 2011 | 02:16 AM
rb12's Avatar
Default Intercoolers
I am about ready to purchase a fmic and was wondering if this fmic
http://vibrantperformance.com/catalo...roducts_id=959
and this kit be all that i need to install it
http://www.034motorsport.com/fabrica...i-p-13141.html
This is going on a 98 b5
any help will be greatly apreciated
Old Mar 1, 2011 | 02:22 AM
Msnickbroderick's Avatar
Actual WIZARD
You can use a universal ebay setup if youre staying with the k03
Old Mar 1, 2011 | 02:27 AM
rb12's Avatar
I'm actually planning on going with a franken turbo. the reason i ask is cuz i dont have the resources to cut the piping to make it fit, so i did some searching and found that kit at 034
Old Mar 1, 2011 | 02:33 AM
Actual WIZARD
A hacksaw would do just fine haha.
Trust me, you can do this yourself for under 200
That core would require some serious rape of your front bumper
Old Mar 1, 2011 | 02:38 AM
rb12's Avatar
lol. what size core would you propose then for around 350-450 hp
Old Mar 1, 2011 | 07:46 AM
vtraudt's Avatar
My 5 cents: I bought ebay kit. Went with 2.75 thick, in retrospect the only mistake. 2.5 would have saved me a ton of (bumper hacking) time. Will a 20x6x2.5 be good for 450? Probably not. But you may check you power goal. Note: larger IC and piping also cost spool up.
Old Mar 1, 2011 | 10:22 AM
rb12's Avatar
True I hadn't thought of that at all. Well um how much did you cut on your bumper going with the 2.75
Old Mar 1, 2011 | 10:26 AM
rb12's Avatar
I'm trying to find an fmic that's maybe around 2.5-3.0 but that is 28ins length wise and I can't find anything can somebody help me out
Old Mar 1, 2011 | 10:33 AM
vtraudt's Avatar
Quite a bit on inside, where the inlet/outlet pipe is, and the lower corners of the IC. It wasn't the amount so much, but since it goes deep, I tried to minimize what I grind away. So I had the bumper at least 20 times on/off, mark where it hits, grind, try, etc. I stopped when I was just barely able to push the bumper back on (under tension).
For the 10% increase in heat exchanger surface area, it was NOT worth it.
I would go 2.5 thick and 2.5 tubing.
Old Mar 1, 2011 | 10:36 AM
vtraudt's Avatar
You sure you can fit it into a B5 A4?
Contact the ebay guys (mine was a 'godspeed') at their ebay store. Click on ask seller, and tell them what you want. They all make various core sizes.
Standard is 20x6x2.5. When you go 26 wide, they may also go higher (26x9 or so?).
