Intercoolers
Old Mar 1, 2011 | 10:44 AM
vtraudt's Avatar
Oh, and for some reason, I couldn't figure out how the pipe with the small connection pipe fits, because it seemed to be 180 degree offset. I ended up using 2x 90 degree plastic elbows from hardware store (for sprinkler systems), screwed them together and made a 180 to fit. I assume it is my limited brain power, can't believe that everyone is making it wrong. But works just fine.
Old Mar 1, 2011 | 11:09 AM
rb12's Avatar
The reason I want a 3in is because 034 sells a kit and it comes with a 3in but with that hose kit I posted
Old Mar 1, 2011 | 05:26 PM
Mike-2ptzero's Avatar
Originally Posted by rb12
lol. what size core would you propose then for around 350-450 hp
I thought you said you were going Frankenturbo? That turbo is not going to give you 350-450hp. lol
Old Mar 1, 2011 | 05:32 PM
Have you seen what a 3" FMIC looks like behind a stock bumper? Like the bumper is bursting at the seams.
Someone elses B5 with a 3" thick core.
I had a 3" with my stock bumper and it was a tight fit without the AC core.
Old Mar 1, 2011 | 05:36 PM
Mr. Phil's Avatar
034 tubing says: Use with intercooler assembly dimensions of 31-32" wide
your intercooler is Air-to-Air Intercooler w/ end tanks (Core Size: 22"W x 9"H x 3.25" thick)
Old Mar 1, 2011 | 06:01 PM
core size never includes the end tank measurement, you have to add about 6"(3" for each side) plus about 3" total for the inlet/outlet, adding those will give you the "end to end" measurement. So a core that is 22" wide will be 28" with end tanks and about 31" from end to end.
Old Mar 1, 2011 | 10:47 PM
meloman's Avatar
Was just about to make this same exact comment haha
Old Mar 2, 2011 | 12:14 AM
  #18
rb12's Avatar
I am still learning but thanks you guys. The reason i said those numbers was because that was what i would want to be making in the end but that will not be for awhile.
I know a frankenturbo won't get me that much power.
What would you guys recommend then as far as a Fmic for a frankenturbo setup?
Old Mar 2, 2011 | 12:15 PM
  #19
Msnickbroderick's Avatar
Actual WIZARD
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
Id get that with 2.5 inch piping kit and be done
Old Mar 2, 2011 | 05:37 PM
  #20
2.5" pipe is for a turbo pushing 500+whp, not for something making 250whp.
