interesting intake heat shield for free. (pics)
Old May 29, 2011 | 12:16 PM
foxracing4500's Avatar
Wink interesting intake heat shield for free. (pics)
deleted
Old May 29, 2011 | 12:28 PM
ObnoxiousDrunk's Avatar
The valve cover looks decent, that heat shield looks ghetto fabulous. Cheap mod for sure.
Old May 29, 2011 | 01:17 PM
Emilgevor's Avatar
If the this tape is sticky on one side i would go to Home depot and buy a piece of aluminum and cut it as close as you can to the shape needed then wrap it in that tape. At least that way it wont look as ghetto.
As for the valve cover i would put little more effort in sanding it down and smoothing the surface then priming it and coating with high heat paint. Looks like you have a lot of cracking/waving going on there.
Looks good tho
Old May 29, 2011 | 02:03 PM
crazyone's Avatar
Listen, the heat shield Idea is Great by you are dealing with Infrared Heat. I don't see the back too well but from what I see is there is nothing back there. What you have there is a good Heat Conductor. Need to have Fiber Glass or some kind of insulation behind it or you will transfer the Heat from one side to the other side. The buffer is a must.
I do similar testing where I work and over the years I have learned alot on Shields, heatsinks and so on.
Old May 29, 2011 | 02:05 PM
crazyone's Avatar
Originally Posted by foxracing4500
at my job I have access to all kinds of tape, my favorites Aluminum tape that can withstand high temps and teflon tape that I cant figure out how I am going to use, teflon tape is very slippery (resists all oils). As you can see I got bored and tried making something, works pretty well the intake felt alot cooler after testing it on a 30 minute trip. Also just recently sprayed my valve covers again.
That Electrical Tape is bad idea. Use High Temperature Wire loom.
Old May 29, 2011 | 03:08 PM
Audisaurus's Avatar
and you think that looks good...?
Old May 29, 2011 | 03:16 PM
crazyone's Avatar
In My line of Work, Electrical Tape is Evil. Good for temporary Fix.
Old May 29, 2011 | 06:34 PM
deleted
Old May 29, 2011 | 06:47 PM
Audisaurus's Avatar
good point, it is a good idea maybe take like 5 min i bet you can make it look good, it sure stops the heat soak
Old May 29, 2011 | 08:11 PM
crazyone's Avatar
On my Bmw's Valve Cover I used high temperature Shrink Paint. That made the Valve Cover look sweet. I am thinking of doing the same with the Audi.
snsamotors
Jan 11, 2010 06:29 PM
Cappachinoo
Jul 1, 2008 12:10 PM
JAVILOPE
Apr 13, 2007 09:41 PM
fobyulous
Feb 16, 2007 06:42 PM
trailboss
Feb 27, 2006 02:45 AM
