Interior lights
Old Jul 20, 2014 | 08:55 AM
rafski's Avatar
Default Interior lights
my backlighting for my radio, doors, dash, etc are only ON when im on Parking lights and if i switch to regular headlights/high beam headlights my interior lights automatically goes off.
what do
Old Jul 20, 2014 | 09:38 AM
ImTheDevil's Avatar
Probably starting to see the deterioration of your headlight switch. Although I haven't seen this particular issue, the switch controls your dash lighting and they're known to be problematic.
Old Jul 21, 2014 | 05:02 PM
jiggleo's Avatar
This is indeed interesting. I had one B5 that was the headlight switch, but another that was intermittent with which gear I was in. it was weird. After a lot of banging my head off the wall and all I finally got a signal tracker and tracked it to the wiring in the trunk along the deck lid. The headlight switch is tghe first and easiest thing I'd check.
Old Jul 21, 2014 | 08:35 PM
OldAudiA4B5's Avatar
If it was me, I'd check all fuses and also have a multimeter handy. Sounds like a pain in the a** type of job once.
On another car, I once had the situation where if I would turn the headlights on, the windscreen wipers would come on and if I would turn the windscreen wipers on, the headlights would come on. It turned out to be a stuffed windscreen wiper motor which was somehow sending a signal back to the ECU and triggering the headlights to come on. A short circuit if you would.
hoovdiddy
Jul 5, 2017 10:19 AM
Jeffreys
Feb 15, 2012 06:30 PM
Angfang
B7 Models
21
Sep 18, 2008 08:55 PM
a4maniac
Sep 7, 2004 11:24 PM
