its driving me nuts!!!!!!!
Old Oct 18, 2009 | 10:02 PM
peterbr17's Avatar
Default its driving me nuts!!!!!!!
ok i have an 97 audi a4 1.8t for a week now the battery keeps dying and i have no idea i took the battery to get check to various spots and the battery is good and so is the alternator i check night after night to make sure i dont leave nothing on i cant figure out whats wrong please help
Old Oct 18, 2009 | 10:17 PM
czwalga's Avatar
Member
I'd put my money that it's the alternator, even if you had it checked.
Old Oct 18, 2009 | 10:21 PM
Andrew149's Avatar
its the battary just cause you check it doesnt mean it isnt anything wrong with it battaries do this all the time there kinda bypolar when they go out they wanna work they cut out and start working its a bit weird and if it was the alternator the car will die while driving it
Old Oct 18, 2009 | 11:29 PM
ghost6303's Avatar
does no body use punctuation anymore?
hook up a multimeter in series with the battery when the car is completely off and measure the amps flowing. it shouldnt be more then 50-100mA or so. if its substantially more, you have something in the car consuming power. if its not parasitic drain, your battery is dying.
Old Oct 18, 2009 | 11:57 PM
screamin demons's Avatar
Start your car, then unhook the batteries positive connection but be careful not to let the wire touch any metal. If the car continues to run, you know your alternator is good and it's the battery.
-Tyler
Old Oct 18, 2009 | 11:59 PM
ImTheDevil's Avatar
Rig a lightbulb in series with the battery. If something is draining current the bulb will illuminate. Pull one fuse at a time and check the bulb. If the bulb goes out when you pull a particular fuse, the circuit that fuse protects is at least partly responsible for the drain.
Old Oct 19, 2009 | 07:37 AM
czwalga's Avatar
Member
Just to add.... make sure it's a DC bulb, not a house bulb.
Old Oct 20, 2009 | 04:04 PM
peterbr17's Avatar
wow guys thank you so much i really appreciate your help
Old Oct 20, 2009 | 04:15 PM
peterbr17's Avatar
ok when i turn on the car and when i turn the lights on the needle that marks the battery voltage goes down everytime i turn something on it keeps lowering till it hits 12v whats up with that??
Old Oct 20, 2009 | 04:54 PM
ImTheDevil's Avatar
That's expected. Everytime you power something up, it loads the system and takes available voltage away.
