Its Good to be back! ^_^
Old Aug 20, 2011 | 02:12 AM
morpheous's Avatar
Default Its Good to be back! ^_^
Hey fellas,its good to be back on the B5 forums,i am sorry i didn't join you fellas at last weekends camping meet,i had to get a AVH-P4300 installed in my B5,I'll come to the next meet,before the summer is over.
I started a new job and moved,since the last meet,hence the reason i haven't been on the forum lately but I'll make myself visible more,being i have the weekends off and i am having issues with Audina. ^_^
Shot out to the fellas i met at the last meet:
Wally
Dave
Bill
Pat
Eric
Chris
Zack
Jeremy
Tyler
Joon
Emil
Nick
Sorry of i left anyone i met out the list,I'm surprised i remembered that many people from that long ago.
Audina Has just went under the wrench,i fixed a major oil leak,it was coming from the rear main seal and another smaller oil leak from the oil filter housing seal.
I got them both done for $630.00,now don't get me wrong,i winced at the price but I don't complain about the cost of repair and maintenance,this had to be done,no other way around it.
I also had the Air pump hose replaced but i am not sure if that fixed the issue,check engine light came back on after i drove it 60 miles with the same codes. Secondary Incorrect air flow and Brake boost Failure,before i got the hose replaced,when i come to a complete stop,my engine would stall and idle ruff,then it would go back up above 1000 RPM and be fine,then after i drive it for awhile,it doesn't do it anymore,it happens more when i first drive it,then it fades out after awhile. then about 2 weeks ago,i came to a complete stop,it stalled then the engine cut off,i had to put it back in park and start it back up,that's when i bring it to a shop,no more mucking around.
After getting the Air pump hose replaced,I don't get the stalling or ruff idle,when coming to a complete stop anymore but the check engine light came back on with those 2 codes,that were there before i had the air pump hose changed. Maybe it with something else? They said the hose had a hole in it,so i am assuming it was the problem but i guess not. Here is a scan i did with my ebay vag-com.
I didn't clear it so i can bring it back to the shop,where i got the Air pump hose replaced,they claimed that was the problem,technically it doesn't do what it did before,so i guess they did fix the stalling and ruff idle issue but the check engine light did come back with the same codes,before the hose was replaced.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16251
Shop #: WSC 63351
4 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 DF
Component: AG5 01V 1.8l5VT USA 1010
Coding: 00002
Shop #: WSC 06435
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Coding:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02444
Shop #: WSC 19411
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 63351
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
End -------------------------------------------------------
I have a reason for not complaining,number one reason is because i just plain am in love with the B5,she is the most sexy Mid sized sedan for her year and class.
Second reason is,i can't afford to pay a 300+ car not every month,i would rather spend 630.00 once every couple months to keep my B5 running,than purchase a newer car,or another used car with a unknown maintenance history,with Audina,i know what has been done to her and when and why.
I just moved to another city and i swear,everywhere i go i see a B5,everyone else feels the same way i do about the B5,people just love the body style and interior.
The maintenance and repair costs is just the price of admission to a very privileged group of car owners
Old Aug 20, 2011 | 11:08 AM
jdahlen24's Avatar
Hey Morpheous, welcome back!
You know, I had those codes once, and it turned out to be that I had misrouted one of the vacuum lines when I replaced them this past winter. Could that be a possibility?
Old Aug 20, 2011 | 12:39 PM
morpheous's Avatar
Thank you friend,
Well,i never got any vacuum lines replaced on Audina,so maybe the issue is a vacuum line?
I'm thankful that my B5 only has 2 codes and 1 check engine light lit.
Tremlett
Dec 9, 2010 10:33 AM
kbdrake07
Jan 1, 2010 04:20 PM
TheJazz7
Oct 2, 2009 04:39 PM
bottlecap
Dec 29, 2008 12:18 AM
