just changed mount....now have bad vibration
Old 02-21-2010, 09:00 PM
big164's Avatar
Default just changed mount....now have bad vibration
I just did my oil pan gasket, and while i was down there i asked the mechanic to change all the mounts. I was there helping with the install. everything seemed to be put back the right way. when i drove the car it seem like i had a wierd vibration and i seem to feel the vibrations more when i accelarate. Any idea what it could be? it did not do it b4.
Old 02-21-2010, 09:03 PM
Andrew149's Avatar
when you do the mounts on this car you haft to lossen the engine mounts and let the engine settle in the mounts and than tighten the bolts
Old 02-21-2010, 09:26 PM
big164's Avatar
This may sound like a stupid question but do i loosen the one that attaches to the cross member or just the top or both? also for how long? sorry i never heard about leaving the mounts loose before lol
Old 02-21-2010, 10:26 PM
Andrew149's Avatar
i have never done it but just loosen them a bit and rev the car not too high than tighten them up and see what you get just keep trying until you find the sweet spot
Old 02-22-2010, 10:53 AM
Mike-2ptzero's Avatar
Yeah you always want to let the car idle and give it a little rpms to allow the engine to settle back into place before you tighten up all the mounts. You also want to make sure that the snub mount is not touching the housing around it, because if it is you will get major vibration.
edrocks3
12-09-2008 10:11 AM
edrocks3
07-26-2008 11:50 AM
audiboyy
01-22-2008 11:34 PM
uptown
10-11-2005 11:45 AM
david9999
11-15-2004 01:33 PM
Quick Reply: just changed mount....now have bad vibration
