Just died
Old Jul 1, 2011 | 10:49 PM
BRET OSSKO's Avatar
Default Just died
Driving home last night car was running fine, then it lost power for a second, then felt normal again . about half mile later it died on freeway at about 70 mph any clues ,pulled codes and it referes to short in bank 1 and 2... 99 a4 2.8 quattro ...the only odd thing lately is my fuel guage bounces ?
Old Jul 1, 2011 | 10:53 PM
BRET OSSKO's Avatar
specific codes are p0441,p1392,p1338,p0102,p1857
Old Jul 1, 2011 | 11:09 PM
Mark C's Avatar
P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P1338 - Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
P1392 - Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
P1857 - Load Signal Error Message from Engine Contr.
The P0102, P1338, and P1392 are the only codes that could have caused a stall. the P1338 code is a bank 1 camshaft position sensor open or short to battery voltage code, P1392 is the bank 2 sensor those two will definately affect the engine running. Chance of two of them failing at the same time is about 0, so you have a wiring problem somewhere relating to those sensors. The P1857 code is related to the ABS system.
Old Jul 2, 2011 | 12:35 AM
BRET OSSKO's Avatar
how do i check if timing belt went bad or could it be a fuel pump issue because of bouncing fuel guage ?
Old Jul 2, 2011 | 08:20 AM
Mark C's Avatar
Does your engine coolant sensor work? On a 96 A4 (the only one I have a wiring diagram for) The camshaft sensor, MAF sensro, engine coolant sensor and outside air temperature sensor all get their power from the same wire coming out of the engine controller.
Old Jul 2, 2011 | 12:29 PM
BRET OSSKO's Avatar
THE car wont start and i did not get a chance to view gauges as i was on a busy freeway when it failed ... i am charging batt today so i can check voltage with a full batt..its just wierd the car was running great
Old Jul 2, 2011 | 01:22 PM
RandomAudiOwner's Avatar
Pull the timing cover off and check to make sure the belt is still in one piece.
Old Jul 9, 2011 | 04:17 PM
BRET OSSKO's Avatar
JUST checked ... its not
Old Jul 10, 2011 | 01:05 AM
BRET OSSKO's Avatar
I will be doing repair myself, so if anyone can post links refering to other posts about what else i may want to look into replacing while i have car torn down i would really be thankfull
Old Jul 10, 2011 | 09:29 AM
ImTheDevil's Avatar
New head gaskets for sure, replace all the vacuum lines (13 ft of silicone hose from Flex Technologies - Your Silicone Hose Solution is more than enough), coolant temp sensor since it's cake to access it with the engine torn down, you'll need valve cover gaskets, new head hardware, and plan on doing the entire timing service (not just belt and tensioner).
