Just replaced timing belt, now ac doesnt blow cold.
Old Jul 30, 2009 | 07:58 PM
Bobbydigital2012's Avatar
Default Just replaced timing belt, now ac doesnt blow cold.
As the title states, I just installed my new timing belt kit and now my ac is not blowing cold at all. The climate control unit is functioning properly, just no cold air. I'm wondering if there is a connection I may have missed when putting it back together?
I have a 99.5 A4 1.8T quattro
Thanks in advance
Old Jul 31, 2009 | 12:10 AM
SAudi's Avatar
did you tension back up the ac blet correctly if its loose it will slip, other than that theres only one wire for the compressor. also are you sure that the compressor is engaging.
Old Jul 31, 2009 | 05:22 PM
The belt is tensioned pretty tight. I went out today and it seems like the compressor isnt coming on, just a fan on the radiator is. Any other ideas?
TY
Old Aug 2, 2009 | 02:08 AM
bumpp
Old Aug 2, 2009 | 06:11 PM
Default *solved*
Problem solved. It was the connector not on the compressor, but the one leading back to a panel box (both are pink and green colored). The wire was being pulled on during my install, so the pin in the connector came loose.
Euro A6
Apr 16, 2010 01:22 PM
mrk3cobra
May 8, 2009 03:23 PM
daveedsfast
Nov 17, 2007 07:30 PM
cooleststan
Jun 27, 2007 06:36 PM
WyoTT
Sep 13, 2006 10:08 PM
