K03 Sport in... Codes thrown
Old May 15, 2011 | 10:51 PM
willie7182's Avatar
Default K03 Sport in... Codes thrown
I was under the assumption that swapping my stock turbo for a K03-29 wouldn't call for an ECU upgrade. Perhaps I was wrong, or perhaps I have a vac leak!?
It drives like sh*t -very jumpy/jerky...VAG COM says:
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-00 - -
Readiness: 0010 0101
Help
Old May 16, 2011 | 02:52 AM
Cristisor's Avatar
I think your car is going into limp mode. Take a look here for more info: http://www.audizine.com/forum/showth...Limit-Exceeded
Old May 16, 2011 | 11:15 AM
Mike-2ptzero's Avatar
Might want to check and see that you have the N75 hooked up or hooked up correctly because your over boosting.
Old May 16, 2011 | 01:46 PM
willie7182's Avatar
Car isn't in limp mode -yet... I'm questioning how I hooked it all back up now. I also removed the DV valve.
Refresh my memory. The DV vac line runs across the front of the engine block right? I saw how everyhitng hooks up to the N75 and it looks good... Perhaps I have to loosen the wastegate?
treyg
Feb 22, 2011 12:29 AM
Audi_Skydiver
Oct 29, 2009 10:02 PM
audizz a4
Dec 2, 2008 01:47 AM
jgm7507
Jul 14, 2008 12:29 AM
BFlan2001
Sep 4, 2005 08:24 PM
