Two codes thrown on my Audi.
P0011 - Camshaft Position Timing Over Advanced
P1118 - O2 Sensor Heater Circ.,Bank1-Sensor2 Open
What do I do to get these resolved as quickly as possible. Replace the sensor for the second code but what about the first? Can I adjust the timing myself or will I need to have it done?
An over advanced code generally means the belt is too tight, or its a tooth advanced. Take off the upper cover and check the tension of the belt. If you can't twist the belt 90 degrees its way too tight. If the tension is fine line it up to TDC and check the marks.
Audi_Skydiver
Oct 29, 2009 10:02 PM
