K04 w speedtuning software up and running!!!
Old Jan 22, 2009 | 12:49 AM
CL AUDI EOUS's Avatar
Originally Posted by RyanSweeney
Guess you can't do that with Speedtuning, huh...
not sure if you can do it at all with a 99
Old Jan 22, 2009 | 01:50 AM
AudiCoupeV6's Avatar
Member
Originally Posted by slopoke
did you have a chipped k03 prior to this?
If so is it a noticeable difference?
And how much was the k04 program?
Yes I had a InMotiontuning chip prior to this and the difference is huge!
I noticed yesterday when I was playing around with my car that in higher gears I'm holding 1.4-1.5bar!
Wow this is the way they should have made the A4!
I think the chip was 200USD!
Old Jan 22, 2009 | 01:52 AM
Member
Originally Posted by A4speed
where did u buy your k04 from? is it the k04-15?
there is a way noticeable difference between when i had my chipped k03s to my hybrid k04 with the Hammer file. i am also excited to try my race file when my gas tank gets low im gonna put a couple gallons of 100 oct in and see how much better that is!
Yes it's the K04-15 and I got it from a audizine member (used).
Old Jan 22, 2009 | 01:55 AM
Member
Not to highjack the thread, but how are you guys changing programs? Does it require a Vag-Com? I'm getting my ECU back from Speedtuning tomorrow.
Atleast at the older A4:s mine fo example you have to change the chip not just flash. So I have had a socket solderd to the ECU so now I just popp out the old chip and push the new one in!
Old Jan 26, 2009 | 02:01 AM
Member
Default Buttdyno
I did a buttdyno to compare the K04 to the chipped 1.8T.
This is done by logging speed time and rpm.
There is a noticable difference but if the numbers are accurate I don't know.
Attached Thumbnails K04 w speedtuning software up and running!!!-chip-vs-k04.jpg
livemsn22
Jan 4, 2014 08:12 AM
chocalotstarfish
Dec 13, 2010 06:31 PM
onepoint8tee
Oct 5, 2008 02:08 AM
paintballpimp765
Oct 3, 2008 11:58 PM
auditurbo381
Apr 15, 2008 11:10 AM
