Keep blowing fuse 34 (Engine timing)
Old Jun 25, 2013 | 04:12 PM
Kenny Gerard's Avatar
Default Keep blowing fuse 34 (Engine timing)
This fuse blows almost instantly.
Now there are exposed wires i see, and i dont know if that could be a problem, Also my MAF has 3 wires connected to it. green, yellow, and Somthing else.. I cut around the outside of the rubber that covers the 3 wires, and there was a 4th wire in there that was black, and really had no where to go.
Please I need some help from someone with wiring experience.
Uploaded with ImageShack.us
Old Jun 26, 2013 | 11:58 AM
Mad Cow's Avatar
Why did you cut open the rubber boot? All it takes is a small screwdriver to pop it off. That black wire is nothing to worry about, it's not supposed to be connected to anything since it's connected to the shielding which is grounded at the other end of the harness.
Fuse 34 powers just the injectors, it goes through pin 8 of the orange body plug connector and is green/yellow from that plug to the injectors. So somewhere in that circuit you have a short.
Old Jul 3, 2013 | 04:39 PM
I didn't cut it open it was like that when i bought the car.. It looked almost melted, I taped it up, but hadent had a chance to look at the fuse or that wiring.
riydan
May 10, 2022 12:18 PM
makhack
Jun 23, 2011 11:48 AM
justanotherjpr
May 11, 2011 10:20 AM
whiteaudiguy
Jul 27, 2009 08:18 PM
raphster
May 3, 2009 09:37 AM
