keyfob
Old Feb 9, 2013 | 11:34 AM
hobber's Avatar
Default keyfob
battery on car went flat,put on new battery but can't get the key fob to work the central locking
Old Feb 9, 2013 | 12:01 PM
tofast2belast's Avatar
put key in ignition and to on position. do not start car. press and hold lock button on keyfob, then press lock on door while holding lock on keyfob, then release door lock button on door then release keyfob button. repeat process for unlock button. turn car off and pull key and check if it works, if not do it again.
Old Feb 10, 2013 | 09:52 AM
hobber's Avatar
tryed this several times, have even put in new battery in keyfob and have new fob, still not working
Old Feb 10, 2013 | 10:04 AM
01 Avant's Avatar
put the key in the door and turn and hold. now press unlock button
Old Feb 11, 2013 | 09:14 AM
mtroxel's Avatar
This is the proceedure that worked on my 96 A4, and on my present 99.5 A4. Did it several times, on both cars.
Steps to reprogram keys to a car they are already linked to:
1. Press and hold the unlock key on a remote
2. Insert key in ignition and turn to on (while still holding unlock)
3. Hold unlock while in the on position for 2 seconds
4. Turn key to off, remove from ignition and release button.
Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
To program new remotes on a car never linked to previously:
1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
3. Exit the car and close the door.
4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
***If you have only one key skip to step 16. Otherwise continue to step 7.***
7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
***If you have three keys proceed to step 10. Otherwise skip to step 16.***
10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
***If you have four keys proceed to step 13. Otherwise skip to step 16.***
13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
16. Remove the key from the ignition.
Make sure that to test the newly program remotes, the original key is removed from the ignition since this exits the programming process. Someone might be a bit frustrated trying to test it with it still in 'program' mode.
I had some diffuculty accessing the programming mode. If it doesnt work then take the key out of the ignition and start over. Rinse lather repeat. It will go eventually.
If you are still having problems after trying it more times than you can count, check the key is right one for year of car or that the key and battery are good.
budnfrida
May 28, 2012 10:49 PM
kriptonik
Mar 5, 2007 04:09 AM
bigblokey0
Jun 18, 2006 05:46 PM
tekarchitect
Mar 29, 2006 12:00 PM
