leak?
Old Nov 6, 2012 | 11:56 AM
98a4guy's Avatar
Default leak?
Ok so my valve cover gasket was leaking so.I went ahead and replaced it over the weekend and drove it around no leaks or smell however this morning I noticed a bit of oil by the nuts on the cover and a slight oil smell in the cabin wen I was sitting still at a light I checked the nuts to see if they were tightened properly and they were any ideas on why it would be leaking?
Old Nov 6, 2012 | 12:28 PM
CCA4's Avatar
What brand of gasket did you use, and what did you torque the VC nuts to?
Old Nov 6, 2012 | 03:18 PM
98a4guy's Avatar
Audi B5 A4 Quattro V6 30v > Maintenance > Engine > Gaskets > ES#259936 Valve Cover Gasket Set - Priced Each - 078198025 this is what i got just the passenger side was in need of replacing and i didnt do the actual torque i kno its 7 ft-lbs but i just tightened them till they were a bit past snug ill check the torque on it later im kinda worried about breaking them since i have never used my torque wrench before and its from harbor freight
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
