light weight pulleys
Old Aug 17, 2012 | 08:07 PM
DylanA4's Avatar
Default light weight pulleys
I have a 2001 2.8 and I bought a lw pulley set. does anyone know how to remove the crank pulley and does it need to be in the service position?
Old Aug 17, 2012 | 11:20 PM
ImTheDevil's Avatar
Yes it needs to be opened up. You might squeeze a ratchet in there but it's very tight and more hassle than it's worth. You do know that common lore says any power increases are basically zero right?
Old Aug 18, 2012 | 06:42 AM
DylanA4's Avatar
I know lol. I was wondering though if I would mess up the engine timing if i tried to remove it. Also does anyone know how to put the car in service position because i never attempted it before.
Old Aug 18, 2012 | 08:45 AM
ImTheDevil's Avatar
You won't touch engine timing when removing the pulley - the timing belt rides on a sprocket behind the pulley. Check the DIY forum and find a timing belt procedure. It'll walk you through service position. It's easy.
Old Aug 18, 2012 | 10:02 AM
DylanA4's Avatar
thanks!
Skychan
Jul 19, 2013 12:59 AM
malhar
May 4, 2012 10:22 AM
Red_sapphire89
Jan 5, 2012 09:28 AM
Ramrod
Jan 28, 2008 04:18 AM
AudiTurbo
Mar 9, 2007 11:32 PM
