Low end power
Old Apr 28, 2010 | 09:30 PM
meloman's Avatar
Default Low end power
So I've finally got money to start modding and my car has a little hesitation off the line and then thanks to the turbo lag don't really feel much until about 2500-3000 RPM's.
What do you guys suggest for some at least semi noticeable low end power gains?
Old Apr 28, 2010 | 09:58 PM
turbo kraut's Avatar
Tech Guru
i would say first off get a boost guage, and check all your vac hoses.... the k03 has almost no lag..... i have and 01 as well and had apr tuning and that thing screamed for about 150 whp...... that being said, if you want more power, do a turbo swap, but you will need to get supporting mods
but like i said get a boost guage, it will let you know what your boost is, and if it is no more than 5 psi then you are in limp mode, but it sounds more like a bad vac leak, i had a "surge" feeling and it was a vac leak....
now if you are a manual tranny car, i sold my apr to a guy and he is not happy with it cause he can't figure out how to recode the trans code and wants to get rid of it
Old Apr 28, 2010 | 10:49 PM
meloman's Avatar
Unfortunately i dont have nearly enough for a bigger turbo and everything else I'd need with that. Boost gauge is almost definitely the first thing I'll be getting, just not sure where i want to mount it yet.
I definitely do feel that "surge" though, not looking forward to replacing those vac lines but I'll let you know if that helps.
Old Apr 28, 2010 | 11:07 PM
mikekey's Avatar
Are you saying you have an APR ECU for sale? I'm a stock manual.
Old Apr 29, 2010 | 07:52 AM
Tech Guru
no, i am saying the guy i sold it to, is tip, last time i talked to him he couldn't figure out how to recode the ecu.... if you are an 01 and interested give me your email and i can let you 2 talk it out
Old Apr 29, 2010 | 10:02 AM
Mike-2ptzero's Avatar
He has to recode the "soft code" to the same code that was in his stock ecu using the vagcom.
Meloman - if your not chipped then that is where you want to start. This will give you a nice gain in low end tq since the chip bumps up the boost level from 11-12psi to 18-21psi depending on the chip.
Old Apr 29, 2010 | 10:09 PM
Tech Guru
i know mike i found a thread and gave him the link.... i think he is kind of new to this
Old Apr 30, 2010 | 11:23 AM
meloman's Avatar
Mike- Getting it chipped is the first big thing I'm going to do and wish i could do it now, I'm planning on getting GIAC's chip I just dont have the cash for it yet.
suuntotim
Jul 25, 2011 12:36 PM
99BlackA4
May 22, 2006 08:43 PM
