lower control arm
Old Nov 21, 2008 | 11:46 PM
vgo's Avatar
vgo
Default lower control arm
it could have been worse but my car is currently in the garage and crippled. passenger lower rear control arm completely dislodged as the bolt must have come loose and f'd up the ball joint. lucky i wasnt driving on the highway.
would replacing this pretty straight forward or do i have to remove other arms to get this installed?
pleaaaase help!
Attached Thumbnails lower control arm-photo038-1.jpg   lower control arm-photo039-1.jpg   lower control arm-photo048-1.jpg   lower control arm-photo049-1.jpg
Old Nov 22, 2008 | 12:41 AM
ImTheDevil's Avatar
The control arms are usually DIY jobs (except for the alignment when needed). The ball joint is the biggest pain out of all of the mounting bolts for a given control arm, so if I were you, I'd go ahead and DIY this one. Check www.audidiy.com or www.audiworld.com for a tech article - there's bound to be something on one of them that'll guide you through the proper steps in the proper order.
Old Nov 22, 2008 | 02:00 AM
ty98a4's Avatar
yea its a diy. that rear bolt is a pita to get out completly. it hits the underbody before it comes completly out. on audidiy i know they have a write up on it. you will can see what i mean on there.
Old Nov 22, 2008 | 02:02 AM
ty98a4's Avatar
pic/step #15 is what iam talkin about
http://www.audiworld.com/tech/wheel43.shtml
Old Nov 22, 2008 | 04:12 AM
lumend13's Avatar
for how long u drove w bad control arms? i need to replace them soon
Old Nov 22, 2008 | 07:45 AM
paul3141's Avatar
hmm.. i just had a lot of my control arms unbolted to replace my suspension..
looks like i'm going to be checking all my bolts for tightness and maybe threadlocking them all tomorrow after seeing this!
Old Nov 22, 2008 | 12:04 PM
vgo's Avatar
vgo
i've had all my control arms replaced roughly 6 months ago after having to tolerate all the "clunk & squeek" for 4montths...i think the mechanic did not torque this particular bolt good enough.
originally i was gonna DIY all the arms but i realized i did not have enough time and would rather have the mechanic go through unbolting all the rusted/seized bolts off the car, and then i'll just apply antiseize on the bolts when they put the new ones on.
i've also got a Haynes manual with me too. I kinda just freaked out when i saw this under my car but its probably the easiest control arm to replace.
jdahlen24
Aug 25, 2011 09:50 PM
cwedholm1
Mar 24, 2010 06:10 PM
crez
Jul 13, 2006 02:46 AM
jacekstefankowski
Jul 8, 2005 02:47 PM
