Manual flywheel fits on auto crank. Is this right cuz it fits pics inside
Old Nov 23, 2010 | 01:03 AM
hiwords's Avatar
there is a diy on audizine done by biketsai, correct me if i spelled his sn wrong. he pretty much lays everything out for you. good luck
Old Nov 23, 2010 | 01:46 AM
99a4wagon's Avatar
I've never done internal work like that. Im not sure I could do it.
Old Nov 23, 2010 | 10:49 AM
Mike-2ptzero's Avatar
Here is Chris's DIY, this was done on his 2001 A4 1.8t which has a 06A block while you have a 058 block. So there might be a slight diffence in the crank flanges.
http://www.audizine.com/forum/showth...ual-Conversion
Picture of the bearing he used as a pilot bearing. I have another customer that lives here in socal that did the tip to manual swap on her B5.5 Passat 1.8t. She too used the same bearing and also went with a CM clutch/flywheel kit.
Info for the bearing
-$19 Pilot Bearing from www.zorkos.com PN#A-6941
If I had the specs for the bearing I could most likely get it right from Clutch Masters.
Old Nov 23, 2010 | 01:04 PM
99a4wagon's Avatar
SO I grind the crank. Install flywheel and place this bearing in flywheel and then bolt tranny up?
Old Nov 24, 2010 | 03:55 PM
99a4wagon's Avatar
Anyone?
Old Nov 25, 2010 | 07:00 PM
99a4wagon's Avatar
How far do I grind it?
Old Nov 25, 2010 | 10:28 PM
FASTER's Avatar
Tech Slut
Bring it and the pilot bearing to a machine shop and explain what needs to be done.
Old Nov 26, 2010 | 03:38 AM
  #18
99a4wagon's Avatar
I dont quite understand myself. I have to tell him how much to machine off.
Old Nov 26, 2010 | 09:54 AM
  #19
But I thought you said your flywheel fits on the crank already?
If so then you just need to get that same bearing in the conversion link and place it in the center opening of the flywheel to act as a pilot bearing.
Old Nov 26, 2010 | 01:36 PM
  #20
99a4wagon's Avatar
It does fit. So that's it ill be fine? Id hate to put it back together and it not work.
