Manual transmission change
Old Feb 11, 2010 | 03:39 PM
Colin1's Avatar
Default Manual transmission change
Hey everybody, I was wandering how often a manual transmission fluids should be changed. I know that Audi says that it is life time fluid but really I dont know of any fluid that is life time. Thats a long time:.
And do yall think if you go so many miles with out doing a fluid change, that it could hurt the transmission? Say 150,000 miles?
Also is these any know problems with the Audi's manual transmisson?
Thanks
Old Feb 11, 2010 | 03:55 PM
Andrew149's Avatar
80,000 miles is when it needs to be change and there are issues with the gears not sinking like 2nd gear wants to go into neutral
Old Feb 11, 2010 | 06:34 PM
johnnyquattro4's Avatar
i've got oil from my intercoolers to my throttle body. any suggestions?
Old Feb 11, 2010 | 06:46 PM
dragonrage's Avatar
Off topic... but if it's a little bit, it's probably normal. Clean it out occasionally, though - especially the IC.
Old Feb 11, 2010 | 07:00 PM
Andrew149's Avatar
You may have a bad head gasket get it check asap
Old Feb 11, 2010 | 07:11 PM
kayakman13's Avatar
More likely a bad seal in the turbo, but thats only if its a lot of oil (like a quart or a half quart)
RedShoeRider
Aug 13, 2012 01:17 PM
MULEPERFORMANCE
Jan 12, 2012 09:35 PM
pattrick02
Jun 24, 2009 06:39 PM
2k2nyc
Nov 26, 2005 10:07 PM
