mass air sensor problem
Old Aug 8, 2009 | 01:10 PM
gedas429's Avatar
Default mass air sensor problem
ok so my air mass sensor is not working and i am going to try to clean it but does anyone have any pictured how to take it out? any do it yourself stuff would help! thanks
Old Aug 8, 2009 | 06:07 PM
rplets15's Avatar
just take off the top of your air box and u will see it there inside the top. its just a round tube looking thing held in with just two phillips head screws im pretty sure.
Old Aug 8, 2009 | 10:08 PM
ghost6303's Avatar
you cant (easily) take the MAF element out of the black tube that it is attached to. just take everything apart and remove the whole tube from the airbox (its about 8" long 2.5" wide). the side with the mesh covering goes upstream of the airflow. you can try spraying MAF cleaner on it (use only MAF cleaner) but if it has more then 100k miles on it, its not a bad idea to just replace it. i gained a good 5mpg by replacing mine that had 120k miles on it.
JEDGE1.8T
Mar 9, 2011 04:35 AM
drft1
Aug 29, 2010 01:36 PM
mudpuppu_94
Oct 5, 2007 02:20 PM
mnsirx
Aug 25, 2007 04:01 AM
TeeTee
Dec 6, 2006 05:31 PM
