metal burrs in intake and intake manifold hoses.
Old Jun 15, 2013 | 07:09 PM
David Narez's Avatar
Exclamation metal burrs in intake and intake manifold hoses.
ok so the other day i did a service to my car you know oil change, oil filter, air filter, spark plugs and MAF cleaning, when i took out the MAF i saw some metal burrs/powder in the inlet housing so i went and check the hose that goes to the intake manifold and it was a little worst, more metal burrs/powder mixed with some oil.
so my question is, since i am a newbie with turbo engines.
Do i need a new turbo? or why i'm getting metal in my turbo hoses?
what are the side effects of this metal burrs in the hoses?
should i change the inter cooler too including all the hoses?
Hre are some pics: Inlet hose Name:  2.jpg
Manifold Hose Name:  1.jpg
Any other advice are welcome thank you.
Old Jun 23, 2013 | 02:01 AM
100+ views and none of you guys can help me out just a little? come on guys please i really need some info. Thank you.
Old Jun 23, 2013 | 11:51 AM
Kamil`'s Avatar
My guess is that your turbo is creating excess heat, and if that heat isn't dissipating quick enough than it will create malfunctions in any system, be that turbo or n/a. Did you check your old oil filter? Cut it open?
Old Jun 23, 2013 | 01:44 PM
Pbcrazy's Avatar
It's possible those metal burrs are coming from your pcv system since they are in your tip, I would personally do three things,
1. Change your oil and look for any metal burrs in the oil
2. Buy a magnetic oil drain plug from ecs
3. Run an oil catch can (or delete pcv and just run the can) and see if that helps
If its not from your pcv system then I'm not sure
Old Jun 23, 2013 | 07:37 PM
Kamil`'s Avatar
Good input^
Old Jun 25, 2013 | 02:14 PM
Thank you guys, I'll check well this things but I don't think that is going to fix my engine. I did a compression test and results were really low. 110, 100, 70, 80. Wet test come out 170, 165, 110, 160. So now I need a new engine. Fnk sucks.
Thank you guys again.
Old Jun 25, 2013 | 03:18 PM
redline380's Avatar
Legal Moderator
really the only place you'll get metal from in the intake is your turbo. i got a ten spot that says you are making contact with your turbine, which you should be able to hear. either way id take the boot off and inspect it.
and before you go rebuilding your engine, verify your compression numbers. its easy to mess up
Old Jun 25, 2013 | 03:58 PM
Pbcrazy's Avatar
If he was contacting with the housing I would understand the metal in the hose leading up to the throttle body but why would there be metal before the turbo? I don't see how the turbo would shoot metal backwards against the incoming air, I might be wrong though
Old Jun 25, 2013 | 04:32 PM
redline380's Avatar
Legal Moderator
the better question to ask would be how would he get metal before the turbo from anything? he shouldnt. theres an air filter stopping flow. he really needs to inspect the turbo soon
Old Jun 25, 2013 | 04:44 PM
Pbcrazy's Avatar
True, remove the TIP and take pictures of the turbine/housing and look for anywhere were the turbine could have contacted the housing. The metal in the inlet pipe just baffles me, the turbo wouldn't spit metal into in, the pcv is just vapor/pressure which shouldnt have metal in it, and the air filter should stop it. I just don't get it
