MIL still flashing...
Old Nov 18, 2010 | 01:34 PM
CBenRieder600's Avatar
Default MIL still flashing...
What is up! Tremendous Thursday to you! So I am sure this topic hasn't been posted umm say three... four million times but I will take the liberty to reset it. Anyways I have a flashing check engine light. I took it to a shop and he told me there were sporadic misfires on all four. Said I needed plugs and all 4 coil packs... and I'm like yeah I'm no tech but I find it highly unlikely all four coil packs failed at the exact same time plus I did plugs 10k ago. Anyways I did some math in my head and found it far more likely to be the Output Control Module. The car is running solid now. No rough misfire run and it no longer smells like a misfire. BUT the MIL is still flashing. Will it need to be reset or does it reset on its own. Do I have another issue that isn't as apparent as a misfire?
Old Nov 18, 2010 | 01:44 PM
dragonrage's Avatar
I have no idea what the details of your car are, but I can tell you that misfires can be caused by many things.
-Ignition control module before (and including) 99
-Spark plugs - what kind are you using and what are they gapped to?
-Coils - all 4 is indeed unlikely
-Front O2 sensor
-poor exhaust flow (partially clogged catalytic converter or something else)
-Timing off (usually will throw more codes though)
-Vacuum leak
-Coolant temperature sensor
etc...
Old Nov 18, 2010 | 06:11 PM
SICKB5's Avatar
If your MIL is still flashing then it is for certain still misfiring.
rynmthw3
Jun 21, 2012 09:15 AM
alex05
Oct 8, 2008 12:31 AM
Mac_17
Sep 21, 2008 02:53 AM
bilney1
B7 Models
May 27, 2008 03:10 PM
sonix
Jan 9, 2007 02:10 PM
