Misfire/ check engine light
Old Jun 13, 2013 | 05:50 PM
RedA4guy's Avatar
Default Misfire/ check engine light
1998 A4, 2.8 DOHC, AHA. The other day when pulling out into traffic the engine stuttered, check engine light came on. Codes where PO302, PO304 & PO300. With the the Bentley manual checked the ohms like the book said to do. All readings a little high. 2-4 wire thru coil pack 27k, wires 6.9k and coil 15k. The plugs (NGK) looked clean. Do I need to replace all?
Old Jun 13, 2013 | 06:43 PM
wmejia989's Avatar
I will recommend changing the spark plugs and get some Bosch ones...I was having the same problems, but my wires were kinda messed up as well. So far no issues.
Old Jun 14, 2013 | 08:49 AM
jmarshall098's Avatar
replace the spark plugs and also check the engine timing and get it corrected if needed. check the distributor and lubricate the cam and contacts.
Old Jun 15, 2013 | 08:33 PM
RedA4guy's Avatar
Put new plugs in and now it purrs. Running great.
Rello2003
Feb 12, 2014 06:33 PM
kiteoregon
Mar 16, 2013 04:12 PM
riggs5
May 24, 2012 04:11 PM
jfree212
Feb 4, 2009 09:14 PM
